What are the functional advantages of a real croc/alligator pattern strap vs one made of just regular cow leather that's been made into that pattern?
can you guess which one is which?I have not seen very many cow leather in croco / gator grain that would fool a true WIS, the general public...yes.
Don't see why it would be an issue with any one who would find a cow leather strap acceptable. The gators that got turned into straps were farmed as much as a cow.wildlife preservation issue
While they may be resource-intensive to produce, hasn't the farming of crocs and gators led to a decrease in poaching and a rebound in wild population? I'm not sure about Australia, but in Louisiana, the wild alligator population has become better off than it was before farming was introduced. (Also, farmed Louisiana alligators, which I'd imagine are the kind most likely to wind up as straps, are often fed nutria- an invasive and overpopulated rodent.)If you care about sustainability, the negative environmental impacts of farming crocodiles are generally very high
Yes the cracks you mentioned on real croc and also the fact that they tend to be very stiff brand new. I always try to buy real crocs sometimes even for cheaper than the strap watches. However I personally prefer shell cordovan which is horse hide for its flexibility and lack of crease/wrinkle. They are much more expensive than calf but so much better than any leather. The Horween no 8 color is also legendary. One problem is if it gets wet the watermarks are very visible prompting you to oil it often.I have had numerous croc and watch straps, and and also belts.[/URL]
