G-Shock GA110 Broken Speed Indicator
Tags
g-shock ga110
2.5K views 9 replies 5 participants last post by  Nazarene
Hello,
Bought a GA110 off eBay from a reputable seller. The speed indicator dial somehow broke-off in transit, and the seller is allowing me to keep the watch free of charge. Is there any way I can reattach the dial? I opened it up, but can't get it to sit right. Is it repairable, or is the whole arm broken off of a pin? Any help is appreciated!
16068485
#3 ·
Ha, glad to present something new to this forum! Learning about this.. seems as if it's not broken, just came completely loose. Someone on reddit suggested using tweezers and a flathead and applying a little pressure to snap it back in. Di you agree?
And to make this even more ridiculous.. I think my cleaner threw the dial out this morning. Does anyone know where I can get a replacement? Thank you!
#4 ·
its pretty worn so possibly the damage was already done and they tried to palm it off to you after they "fixed" it? it is very rare to have this happen on a genuine model tho.
the hand itself should just slide back onto the post. you might need a tiny drop of glue (id use a tiny drop of contact adhesive)
#7 ·
For clarity, watch is fine and in working condition. I'm just missing the speed indicator hand. Trying to figure out how to replace/repair it. Casio says they don't sell the part, I'd need to send it in for a repair (And they wouldn't give me an estimate on how much it would cost)
#8 ·
kskill,
Here are some rough numbers that may give you an inkling as to service and repair costs. These are from the Singapore Service Center last year.
This repair shop is in Wisconsin:
Casio Watch Repair by The Jewelry Center
Here is an outline of some of their prices.
  • Watch Battery Replacements
    $3.99 and up
  • Crystal Replacements
    $40 and up
  • Stem & Crown Repairs
    $50 and up
  • Movement Overhauls & Cleaning
    $90 and up
  • Band Repair or Replacement
    $19 and up
  • Band & Case Refinishing
    $70 and up
  • Add or Remove Existing Links
    $15 and up
Celt
