How thick is too thick?
22K views 44 replies 38 participants last post by  JimD303
I've got several Vostoks which due to the design are quite tall. A 3mm thick, highly domed crystal and a caseback engineered to sit proud of the case means these watches sit at 15mm. Add a 1.2mm NATO and you're looking at almost 18mm! Luckily on me the caseback sinks into my wrist, somewhat lowering the caseback's effect and the crystal being clear visually doesn't make the watch look tall. You won't, however get one of these under your shirtsleeve.
What's your thickest watch and how thick do you feel is too thick?
#2 ·
My thickest watch is my G-shock GPR-B1000-1 GPS Navigation watch, at 19.9mm thick. It's okay though as it's a hiking/outdoor watch.
"Too thick" would be the Omega Planet Ocean Ultra Deep Professional at what - 28mm??
Everything else is fair game. ;-)
Reactions: Simon
#5 ·
Says who? I regularly wear my 15.1mm tall Jazzmaster auto chrono under the shirt cuff.
When the thickness is due to a domed crystal, it usually slides under the cuff pretty well. Thick straps and high, edgy case flanks are the real problem. See the illustration below, that watch could just as well be 12mm tall in the middle without making any difference.
Anyways, my thickest watch is 17.2mm and it's quite heavy (190g), which is far more relevant for wearing comfort than thickness in the middle.
#7 ·
Oddly even thickness is a dimension that seems subjective depending on how a watch wears. My precista PRS18A is only 12.5 mm but seems to stand up tall on the wrist. (Not my photo).
Personally I draw the line at 15mm, no matter how the watch might wear.
Sent from my Pixel 3 using Tapatalk
Reactions: lechat and old45
#10 ·
No surprise at all. That's what I meant with an edgy, high case flank in my post above. My Obris Morgan Explorer had the same 12.5mm thickness and shape and also felt thicker than a 14mm watch with rounded flanks and a domed crystal.
#12 ·
Well, there are really three considerations at play here: actual thickness, perceived thickness, and weight.
- Actual thickness is obvious: the thicker the watch, the more difficult to cover it with a cuff, the more likely you are to bang it into things.
- Perceived thickness is how thick it looks on the wrist. For example, the Rolex Submariner is 12.5mm thick, but about 2mm of that is the protruding caseback that isn't really seen because it nestles into your wrist. The problem here is one of perception: how "slab-sided" does your watch look?
- Finally, there's weight. The thicker the watch, the heavier it is - unless it's plastic (think G-Shock) or titanium - and the more uncomfortable it will be as the day wears on.
So in a true "tale of two watches," consider the Bremont and the Blancpain in my sig line. The former is 17.5mm tall, the latter is 14.8mm. Both thick watches. But the Bremont is in titanium, so it weighs considerably less than the Blancpain. And Bremont uses a design they call their "Trip Tick" case, which breaks the case into three contrasting parts, which helps prevent the case from looking slab-sided.
Or maybe consider the Omega Grey Side, which is 16.5mm thick, but A) is made out of ceramic thus mitigating weight, and B) doesn't look as thick as its true thickness, because about 3.5-4mm of the thickness comes from the "sapphire sandwich."
So normally, I'd say no more than 15mm thick, especially on steel bracelet, because you're going to have weight issues. But if you can mitigate the weight and perceived thickness, you can conceivably go thicker.
Regards,
Alysandir
#36 ·
My Grand Seiko Hi-beat GMT is 13.9mm thick, and it's sits almost a bit too high (but the other design facets make up for it). I prefer my watches to be 12mm and under.
One of my tallest watches is also a Grand Seiko GMT; mine is 14.1mm thick. Only my Ball Skindiver is higher at a thickness of 14.3mm. I feel both are too tall because they don't fit under some of my coat and shirt cuffs.
Ideally I'd prefer my watches to be under 12mm. I have two dive watches that are ~9mm (still 200M WR) and they're wonderful.
#18 ·
For me, anything over about 12mm is too thick. That's why I love the 3239 Ingenieur at about 10mm:
#25 ·
11mm for me, assuming the case back isn't pushing the watch out from my wrist. The pic in the OP looks like the watch is hovering like a land speeder. Criss Angel signature model.
Even though the Vostoks are 15mm they actually wear much thinner and the thickness is misleading on the wrist. If they were to use a "normal" crystal and a "normal" caseback they would only really be in the neighbourhood of 8-9mm.
#21 ·
I had a watch that was 15mm (44 diameter) and I had to let it go because it was not comfortable at all. Too heavy and too top heavy. Also the thickness was all in the case. I have another one at 14.5 but that is 2.5 of a domed box crystal and so it does not feel thick to me and it wears fine. Since that experience I tend to stay away with watches that are over 15mm. The thinner the better for me.
#26 ·
Indeed, this is correct.
I swapped a display back onto a Vostok 710 Scuba Dude, which easily took it up to 17mm ...
No chance of fitting under a normal cuff ... but I loved it anyway! 17mm thick = more watch to love!
#27 ·
Thickness needs to be in proportion to case width and L2L length.
Tall and thin looks out to me, eg the Tudor black bay, far too tall for the other case dimensions, fixed by the 58.
#30 ·
Pretty sure the now discontinued Sinn U200 was proportionate to an actual hockey puck, or possibly Abe Lincoln's hat.
