Hydro mod oil best to use
25K views 16 replies 8 participants last post by  TheBearded
#1 · (Edited)
Hi,
I would like to try the silicon oil in my Rangeman, without to remove more than back metal cover, what viscosity do you suggest to use?
I find different values, from 50 to 12500...
I'm tempted to buy the V100, liquid to close all spaces inside the case...
Thanks
#3 · (Edited)
I had an interest in doing this some time ago, and the thinking then was the lower the better. Still have a can of 10wt silicon oil knocking about the garage somewhere. Couldn't get over the fact that a hydro mod prevents the auto EL from working!
mmm... just realised the pack also has '100' on it, so obviously I don't understand the units of viscosity! LOL
#4 ·
As mentioned in several other threads, don't use a silicone-based oil in your watch. It is likely that the oil will react with luminous coatings if present, and there is some suspicion that it will cause gasket/cushioning material in the Rangeman to swell. Best to use some kind of Teflon-based oil or 3M Flourinert if you can source some. I have seen some Teflon-based shock oil for R/C cars but, even the ones with the lowest viscosity ratings are many times thicker than Flourinert - shouldn't be a problem, though, if you are hydro-modding a digital watch.
#12 ·
If you're really interested in doing a hydro mod to an analog watch, I'd suggest starting with a cheapie. Here's a good read about someone's Hydro mod adventures.
