Longines spirit 37 owners plz help
1 reading
1.7K views 3 replies 4 participants last post by  Nokie
Picked up my 37 spirit just wanted to check this is correct. When setting the date on mine at position 1 the second hand continues to run is this normal for the 37mm? Obviously when pulled out further the time stops to make the time adjustment. If someone could let me know would be much appreciated. I’m also finding the quick release bracelet not that quick release haha.
#3 ·
What @rationaltime said is true of most every watch out there, both quartz and mechanical. I have a 40mm Spirit and the movement only stops when the crown is pulled all the way out, not in the date position. The 37mm and 40mm have the same movement.
Some older mechanical movements might not stop the movement when the crown is pulled all the way out. One that comes to mind is the Omega Speedmaster (with 1861 or older movements). Those movements that don't hack tend to be time only, no date. I've never seen a quartz that doesn't act like your Spirit though.
Just be careful, do NOT change the date between 9pm-3am is the rule of thumb for any watch with a fast date advance. Doing so in that time window can trash the date change mechanism, it's not guaranteed it'll damage it but better safe than sorry.
