Number of hand wind turns on Miyota 9015 to power it?
15K views 6 replies 6 participants last post by  aechme
Hi!
How many hand wind turns do you have to do to hand wind a mioyta 9015? I have a 9015 watch but wear it only a few times a month. I hand-wind it daily with about 20 full rotations. It works but it seems like I may be over-winding it.
So question is, - how many winds should you make, and is there some sort of database for this?
#2 ·
I think it's about 20-25 turns to wind a 9015, but you don't need to worry about overwinding, as that movement has a slip clutch that will prevent damage if you overdo it.
I've always operated under the notion that it's best to wind just enough to get a movement going, and then let the rotor do its work while wearing the watch. That's sort of the point of an automatic isn't it?
#4 ·
I wind my watches with Miyota 9015 movements ( 5 of them ), as suggested by docvail, 40 180 degree turns to give them full power. I then put them on watch winders set to clockwise turning only and 860 turns per day. My watches are always ready for "grab and go". Cheers, Bill P.
#5 · (Edited)
Per the Citizen/Miyota spec/manual:
Operating method
Winding the mainspring, adjusting the hand, date is done by the below procedure.
(1) Winding the mainspring
Automatic winding watch can be also manual-winded by turning the crown in "A" position. Wind 15 ~ 20 times clockwise until second hand starts to move naturally.
http://www.citizen.co.jp/miyota_mvt/9015/pdf/spec_9015.pdf
