Seiko grand quartz 9943 movement help
6.7K views 6 replies 6 participants last post by  hi_bri
I have recently bought a seiko 9943 and the seller claims the watch seconds hand vibrates with a battery but doesn't run. No acid leak or water damage.
What would likely be the issue, sticky oils etc?
Does anyone have experience with getting the seiko twin quartz movements going again, any troubleshooting tips?
Also anybody here had a twin quartz serviced in the UK or europe and how much does it roughly cost? Feel free to pm me if you do not want to discuss prices on here.
Thanks!
Here's a pic of it, the dial and case shape won me over. Realistically returning it to =/- 10spy probably won't happen but anything close would be great!
#5 ·
If you're lucky it's just a duff battery. Otherwise, the cost of getting this movement working again may leave you wondering why you didn't wait for a better example to come along. Even if it's just 'sticky oils', the movement will need a complete tear-down. These days this is rarely done by technician-grade watch servicers whose primary function seems to be to swap old movements for new. So your watch will be passed up the chain for a more in-depth examination and service. You have now exceeded the cost of the watch before they have even told you whether or not they can fix it.
They probably will be able to fix it, of course. It may be that one of the gears is worn. Then comes the question of whether they can find the right replacement gear (maybe a donor movement?) or whether they could fabricate a gear (how much are you looking to spend?). A competent watch maker can do this or you could go via Seiko.
Seiko may say they can't fix it if they haven't got spare parts in stock, whereas an independent watch maker may be more willing to cobble together a solution from a donor movement. Seiko, on the other hand, are the only ones likely to be able to regulate the watch back down to 10 SPY. And it would probably have to go back to Japan for that.
Seiko have told me, in the past, that they would be willing to work on my Twin Quartz watches (if they were sent back to the factory), but the cost of doing so has always put me off. I am right now in the process of regulating a cal 9923 and it is a pain in the backside for reasons explained at great length elsewhere.
#7 ·
Although some of our HAQ owning colleagues will cringe at this suggestion, if it is indeed some "minor" hardened oils, you could put the watch on a line-cleaning device (essentially a demagnetizer) and you might get it running again. You might need to expose the movement if it has a antimagnetic shield on the caseback. This is worthwhile if you just want it running and not running back at factory spec.
-Brian
