I’m looking to upgrade the 7s26 movement in my Seiko SKX013 with a 4r36. I’ve done movement swaps on the full sized SKX cases before. I know a SARB059 crown and stem is needed when you swap in a 4r36 movement however my questions is:
Will a SARB059 crown and stem work on the mid-size SKX013 case or will I need a different crown and stem for the movement upgrade?
I’ve seen mention of upgraded 4R movements in the smaller case so I know it can be done, just need a little info help regarding the details.
Thanks in advance.
Thanks in advance.
