Ingredients: A Soldering iron
Yo.
I found a pretty good solution to ripped, snapped or torn straps.
It's not the prettiest solution so an immaculate finish isn't going to be the end result (although with practice who knows?) but it's solid and keeps the strap from breaking or becoming non-usable.
Strap from a G-7700:
Slight tear in the band but looked to me like it would've gotten bigger or at least split as far as the tang hole, the spot being right where I'd fix the buckle too.
First attempt at a fix: I tried superglue and that worked for about 1/2 hour before cracking. :/
Scrap that one then, kinda expected it.
I was going to attempt using 2 part epoxy glue with less hardener thus giving a softer end mix but was feeling impatient and then had a lightbulb moment...
Yeah!!!
A few minutes later (on full heat) and ta-da!!!
Solid and still flexible albeit a little stiffer than the unmelted resin. Perfect!
I'm gonna get a new set of bezel/straps for this watch at some point but just thought I'd share a quick fix for anyone who might end up in a similar predicament.
Yo.
Yeah!!!
