Hello guys,
I have just put together a simple, but very detailed guide that explains, through some basic formulas and not subjective opinions, why 3ATM pressure is a lot more than we are lead to believe.
Before going ahead please always follow and give priority to your watch manufacturer use recommendations and instructions. Please always follow recommended service intervals.
The purpose of this thread is to have an educated conversation about "simple" laws of physics. The differences between Water Resistance claimed by manufacturers and the recommended use is not the subject of this thread.
Edit:
I will be adding a Q&A section at the bottom as soon as time will allow it, questions like "does angle of impact, time, temperature etc have an effect?" seem to reoccur frequently. The short answers, giving what would be a plausible and practical scenario (even if extreme), is NO. These changes aren't significant enough when put in relation with our examples/calculations.
Service intervals and maintenance does play a major role.
Please have a look at the formulas listed below anyway, they have been simplified to the max for an easy reading, with a clear and concise explanation right under each of the two paragraph.
These are the key formulas and examples needed to explain how a 3ATM TESTED watch will actually perform.
For our first example, we looked at how much pressure (in Pascals) 3 ATM equals to.
In this case 303,000 Pascals. Why is this number important?
Below we are now going to look at how many Pascals are generated the Dynamic Pressure with three different examples (swimming, jumping in water) and we will compare it with those numbers.
This should provide a definitive and unbiased answer about water resistance.
It should be evident that when we compare the dynamic pressure generated in our three different example above, even in the most extreme case (watch impacting the water at 80km/h-50mph) the pressure generated by that action, in this case 242,000 pa, still happens to be lower that the 303,000 pa that a 3ATM watch will be capable of withstanding.
This thread is merely the a scientific explanation of this empirical but very excellent experiment Seppia conducted a while ago.
It is a fantastic thread and here's the link:
CREDIT: SEPPIA
Can I dive with a 30m WR watch? An empirical experience
I have also created a video that contains the exact same formulas, with a step by step explanation of everything that has been mention in this thread.
The video does not add anything that hasn't been written here already. However should you wish to view it, please find the link below:
Looking forward to hearing all your feedbacks.
Edit:
CREDIT: SEPPIA
